Date/Time: Fri, 07 Feb 2025 23:56:39 +0000
Disconnects (zeroing) in Denali Depth over the last week (user email)
View Count: 543
[2020-05-28 13:43:39] |
SC Support - Posts: 1930 |
on Denali Version 2109 bid & ask depth bars showing up as zero difference, sum, ratio, all showing Zero Date Time Of Last Edit: 2020-05-28 13:57:31
Input name - Calculation Mode. Value - Sum Bid Side.arc.png / V - Attached On 2020-05-28 13:28:18 UTC - Size: 42.58 KB - 241 views getting blanks in depth and ask bars.oxm.png / V - Attached On 2020-05-28 13:28:36 UTC - Size: 62.85 KB - 183 views |
[2020-06-22 01:00:17] |
This will take some time to understand. Is the user still experiencing the problem?
