Date/Time: Fri, 07 Feb 2025 08:11:33 +0000
[Programming Help] - ZigZag Function
View Count: 875
[2020-05-28 02:17:36] |
Eddie - Posts: 12 |
Is there an ASCIL function for ZigZag from which I can extract zigzag top or bottom values for programming? If no, can you create one in the future? Thanks
[2020-05-28 08:28:31] |
Flipper - Posts: 65 |
Have a look at the study code in Studies7.cpp in your C:\SierraChart\ACS_Source folder. The study is scsf_ZigZagStudy(SCStudyInterfaceRef sc) All the array values are there for using in ASCIL or Study Subgraph Reference. |
[2020-05-28 14:00:40] |
ForgivingComputers.com - Posts: 995 |
If you enable "Additional Output for Spreadsheets" you will be able to read the subgraphs that give you what you are looking for. |
