Date/Time: Mon, 25 Nov 2024 06:56:26 +0000
Symbol Root - ACSIL member
View Count: 1035
[2014-01-22 22:02:56] |
ejtrader - Posts: 688 |
SC Team - is there any ACSIL member available to determine the symbol root? At present - sc.Symbol.GetChars() - would give me actual symbol name. Interested in knowing if there is any way to find the symbol root instead. Thanks Date Time Of Last Edit: 2014-01-22 22:19:47
[2014-01-22 22:04:08] |
No because there is no standard for this. Every symbol format is different.
