Date/Time: Mon, 16 Sep 2024 19:21:13 +0000
Missing data in FX datafeed
View Count: 1229
[2014-01-22 21:31:58] |
AndyL - Posts: 119 |
There appears to be missing intraday data for 16:05 to 16:40 today in EUR/USD and every other fx symbol i have checked. I tried 'Delete and download data' but it didn't fix it. Is this related to a Fxcm outage or technical problem?
[2014-01-22 21:47:43] |
Yes, there was an FXCM outage and we will have to patch the data. This is a time-consuming process. We will try to have it done later today.
[2014-01-23 07:06:54] |
tobi - Posts: 351 |
Still working on this? When approx. will it be patched?
[2014-01-23 07:10:01] |
We did not get to it yet.
[2014-01-23 07:37:02] |
What will help speed this up as if you let us know what specific symbols you are charting? Some symbols we may not be able to patch because we have no alternative source of data for them. This would be some of the CFDs. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-01-23 08:11:45] |
tobi - Posts: 351 |
For me this would be the following FXCM symbols:FX: EUR.USD, GBP.USD, AUD.USD, NZD.USD, CAD.USD, CHF.USD EUR.JPY, GBP.JPY, AUD.JPY, USD.JPY CFD: US30, SPX500, GER30, JPN225, USOil, XAUUSD Please let us know here when the patch is done. Thank you! |
[2014-01-23 21:29:11] |
We will patch the particular symbols that we can.
[2014-01-25 03:17:18] |
Sierra Chart - Max - Posts: 5662 |
The following symbols have been patched: "XAUUSD.scid" "EURUSD.scid" "GBPUSD.scid" "AUDUSD.scid" "NZDUSD.scid" "USDCAD.scid" "USDCHF.scid" "EURJPY.scid" "GBPJPY.scid" "AUDJPY.scid" "USDJPY.scid" "EURCAD.scid" "CHFJPY.scid" "GBPAUD.scid"
Follow the steps here to redownload the data: http://www.sierrachart.com/index.php?l=doc/helpdetails7.html#RefreshWithData Sierra Chart Support Date Time Of Last Edit: 2014-01-25 03:18:16
