Date/Time: Sat, 08 Feb 2025 02:10:53 +0000
EUREX
View Count: 1110
[2020-05-27 17:59:32] |
Ferenc Sand - Posts: 3 |
Hello Now i have Denali TT CME Datenfeed,I would Like to add EUREX Thank you Ferenc |
[2020-05-28 11:50:42] |
Currently you are actually not using the Denali data feed and must be receiving delayed data. To use the Denali Exchange Data Feed, follow instructions here: Denali Exchange Data Feed For EUREX you need to use this data feed: Sierra Chart Exchange Data Feed When using both you receive a 12 USD credit per month to your account. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-28 19:35:57
[2020-06-23 14:36:15] |
Hello For EUREX you need to use this data feed: Sierra Chart Exchange Data Feed Hel my please I did not find 12 usd EUREX datenfeed on this link Thank you Ferenc |
[2020-06-23 18:23:39] |
The $12.00 USD is a credit that you would receive on your account if you use both the Denali Exchange Data Feed and the Sierra Chart Exchange Data Feed in the same month. This would not be applicable to you, as you do not have the Denali Exchange Data Feed active. The cost to add the EUREX would be the following: - Sierra Chart Exchange Data Feed for 20 symbols: $25.00 USD per month - EUREX Exchange Fee: $21.00 USD per month Total: $46.00 USD per month Follow the instructions here to setup the Sierra Chart Exchange Data Feed with the EUREX exchange: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
