Date/Time: Fri, 07 Feb 2025 08:09:40 +0000
Gold, roll GAP
View Count: 687
[2020-05-27 17:56:47] |
arruga - Posts: 253 |
How can I fix this roll issue? http://www.sierrachart.com/image.php?Image=1590602107142.png |
[2020-05-28 20:02:47] |
This is what we see for a Daily bar chart for the micro gold: http://www.sierrachart.com/image.php?Image=1590696038612.png So the first thing we recommend you do is re-download the daily data for the last two contract months: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data And see if that corrects the gap. It should. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-28 20:02:54
