Date/Time: Fri, 07 Feb 2025 08:06:54 +0000
cannot connect through cqg says cqg not enabled on package
View Count: 530
[2020-05-27 17:56:36] |
john baker - Posts: 12 |
cannot connect because of the above message when selecting cqg
[2020-05-27 18:28:44] |
Your Sierra Chart account is active. We want you to restart Sierra Chart and perform a Forced Login: Sierra Chart - Software Login Instructions: Forced Login Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
