Date/Time: Fri, 07 Feb 2025 10:16:04 +0000
[User Discussion] - buttons
View Count: 536
[2020-05-27 17:45:29] |
User684531 - Posts: 4 |
I've updated Sierra to the latest version. The drawing tools are now labeled by their name instead of their picture ie. text: "horizontal line" instead of the picture of a horizontal line. How can I get back the pictures? thanks |
[2020-05-28 18:37:42] |
Yes. Refer to the notes here for this particular version (2065): https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2065 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-28 18:38:00
[2020-05-29 15:55:01] |
Thank you
