Date/Time: Fri, 07 Feb 2025 12:49:45 +0000
Stop Limit attached question
View Count: 609
[2020-05-27 16:16:35]
JYohan - Posts: 25
Hello, is there a way to attach multiple stop limits, when I hit the Buy keyboard shortcut? For instance, I buy at $10.00 and the attached order puts two Stop Limits at $9.00, and $8.50 to lower the chance of blowing past my stop, without risking a market order? I know there are OCO orders but it's a bit slow without the keybind.
[2020-05-28 18:53:04]
Yes through Attached Orders:
Attached Orders: Using Attached Orders and Attached Order Settings
You need to add two stop orders and each one needs to be in a different OCO group, 1 and 2:
Attached Orders: OCO Group (Group)
[2020-05-29 05:01:30]
JYohan - Posts: 25
When I do that, the window turns red, as if waiting for another target order. But even if I add an another target order and link it to OCO group 2, the trade window acts as though it doesn't exist. I'm using a custom trade shortcut to make the initial trade, if that helps.
[2020-06-02 03:37:38]
JYohan - Posts: 25
Attached is a simple example of what im referring to. The first picture works fine and is green but once I add a 2nd stop, it turns Red and does not work even if I add a target or two. The 2nd stop even defaults to oco group 2.
imagetradess.jpg / V - Attached On 2020-06-02 03:32:36 UTC - Size: 106.12 KB - 253 views
[2020-06-02 05:06:49]
You need to increase the quantity on the first tab of the Trade Window to 2.
[2020-06-02 14:47:48]
JYohan - Posts: 25
I don't think I worded the original question properly. That does change it green but I want the attached order to sell at one stop or the other, not both. So basically I want them both on oco group 1 but the window won't allow it. Setting a stop limit to "all oco groups" doesn't work either.
[2020-06-02 19:38:11]
This is not supported what you want to do.
Date Time Of Last Edit: 2020-06-02 19:38:18
