Date/Time: Fri, 07 Feb 2025 10:13:17 +0000
[User Discussion] - Average value High-Low (Bar Difference) for the last 8 bars
View Count: 1900
[2020-05-27 14:10:59] |
ULADZIMIR VALASACH - Posts: 38 |
Good afternoon! Bar Difference How to calculate the average value High-Low (Bar Difference) for the last 8 bars? Can it be plotted in chart? Date Time Of Last Edit: 2020-05-27 14:12:15
[2020-05-27 23:06:42] |
ochocinco - Posts: 29 |
Can you clarify what is being asked? Are you wanting to see the rolling average of the highest high and lowest low over the last 8 bars? (HH+LL)/2 |
[2020-05-28 05:57:11] |
No - we are talking about price volatility: high - low. For example: the volatility of the eighth bar from the current = 12, the seventh bar = 8, the sixth bar = 14 ..... And then the average volatility = 11. |
[2020-05-28 10:09:19] |
(H8-L8)+(H7-L7)+(H6-L6)+(H5-L5)+(H4-L4)+(H3-L3)+(H2-L2)+(H-L)/8
[2020-05-28 10:37:46] |
Ackin - Posts: 1865 |
I think it is more appropriate to use Study Subgraphs Difference and modify its result by "Based On" by studying Moving average - simple ..... or better by Linear regressionStudy Subgraphs Subtract/Difference Moving Average - Simple if you include gaps among Close / Open bars as True range, then it's basically a classic ATR Average True Range note if you like math and are looking for a deeper essence and a slope of volatility, you can add a cumulative sum of the difference in bar size Date Time Of Last Edit: 2020-05-28 10:45:34
[2020-05-28 13:16:32] |
Sawtooth - Posts: 4173 |
The Average Daily Range study will do this.More specifically, it does this when set to Length of 8: ((H[-7]-L[-7]) + (H[-6]-L[-6]) + (H[-5]-L[-5]) + (H[-4]-L[-4]) + (H[-3]-L[-3]) + (H[-2]-L[-2]) + (H[-1]-L[-1]) + (H-L))/8 Its name should more accurately be Average Bar Range. Date Time Of Last Edit: 2020-05-28 13:19:55
[2020-05-29 09:58:50] |
Thanks - but I can not find Average Bar Range...
[2020-05-29 10:55:25] |
I try Average Daily Range - I think it works! Thanks!
[2020-05-29 11:09:36] |
Is it possible to display a BarDifference/AverageDailyRange on a chart?
[2020-05-29 12:05:18] |
Use the Study Subgraphs Divide/Ratio study.
[2020-05-31 21:22:25] |
thank you very much - you helped a lot !!
[2020-05-31 22:51:25] |
User48838 - Posts: 121 |
You could also compute an 8 period moving average of the high and low, then subtract those two values.
