Date/Time: Fri, 07 Feb 2025 07:54:47 +0000
How to avoid of opening bigger position
View Count: 774
[2020-05-27 10:43:02]
manfretto - Posts: 117
Is it possible to limit the maximum number of contracts to be opened. I trade from sierra chart routing. I use keyboard shortcuts to open and close a position. I would like to avoid the risk that the maximum contract allowed to be opened is limited by my account balance only.
It is too easy to click key shortcut twice and double the position by accident.
[2020-05-27 12:51:22]
Yes. This is supported through the Global Symbol Settings:
You can set position limits per symbol or globally.
