Date/Time: Fri, 07 Feb 2025 15:22:18 +0000
Price Bars in 1 Pip Increments
View Count: 918
[2020-05-27 10:04:17] |
User513662 - Posts: 90 |
Is it possible to display time, volume or tick price bars in 1 pip increments rather than 1/10 pip increments? I can see how to change it on the price display, but I am not seeing how it can be done for the price bars on the chart. I am using the LMAX live feed. Many thanks. |
[2020-05-28 19:14:38] |
Have a look at using this study to accomplish what you need: Round Price Bars to Tick Size You will need to adjust the Tick Size to what you want for the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-05-29 03:17:39] |
Many thanks. This is perfect.
[2020-06-04 05:02:17] |
Is it possible to have this working with the chart candle display in 1 pip increments, but place orders at say 0.5 pip increments on the chart with chart trading?
[2020-06-06 22:45:44] |
Can someone please help with the the question in post #4?
[2020-06-07 00:55:52] |
The only way to accomplish what you want in post #4 is to set the Chart Tick Size setting to what you want to use for the increment for trading.
[2020-06-07 08:58:40] |
User267701 - Posts: 66 |
What solution of the two would help me with trading CME FX micro contracts from a standard contract chart?
