Date/Time: Fri, 07 Feb 2025 07:41:43 +0000
Controlbar
View Count: 552
[2020-05-27 10:00:19] |
RIFT - Posts: 124 |
Hello SC team, can you please make the float control bar vertical too? Thank you very much! |
[2020-05-27 12:49:48] |
You just need to resize it to make it vertical.
