Date/Time: Fri, 07 Feb 2025 07:23:28 +0000
Custom DLL Study
View Count: 723
[2020-05-26 23:21:50] |
User716575 - Posts: 24 |
Hi I'm getting a warning. The Custom DLL study Usercontributedstudies _64.scsf _BackroundBars has just caused a CPU exception. I don't use this custom study. Any idea what is going on? |
[2020-05-27 02:01:58] |
The easiest solution to this is to update Sierra Chart to the very latest prerelease 2111 to get the updated UserContributedStudies file automatically. Instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
