Date/Time: Fri, 07 Feb 2025 06:38:12 +0000
[Programming Help] - sc.BaseData[SC_ASK_PRICE] instead of sc.BaseData[SC_LAST]?
View Count: 636
[2020-05-26 15:31:40] |
clspxes1 - Posts: 4 |
ACSIL is powerful. Just have a quick question that I will pose through a scenario. In the example we have if (sc.CrossOver(sc.Close, SimpMovAvg) == CROSS_FROM_BOTTOM) What if someone wanted the Bid Price rather than the closing price of a bar? i.e. I've tried: float BidPrice = sc.BaseData[SC_BID_PRICE][sc.Index] -------------------------------------------------- float BidPrice = sc.BaseData[SC_BID_PRICE][0] --------------------------------------------------- float BidPrice; BidPrice = sc.SymbolData->BidDOM[0].Price; (this is from a user contributed study example (did not work either)) --------------------------------------------------- EDIT: Of course, followed by placing the bid/BidPrice into the if statement; sc.Crossover(BidPrice, SimpMovAvg) EDIT2: The title of the thread says SC_ASK_PRICE but I meant SC_BID_PRICE So, in short, I'm looking to change the logic from: if (sc.CrossOver(sc.Close, SimpMovAvg) == CROSS_FROM_BOTTOM) to if (sc.CrossOver(BidPrice, SimpMovAvg) == CROSS_FROM_BOTTOM) If you could explain it I'd really appreciate it. If you'd like me to pay for phone support instead just let me know. Date Time Of Last Edit: 2020-05-26 15:40:58
[2020-05-27 05:56:29] |
Flipper - Posts: 65 |
Are you sure you have bid prices and you have sc.MaintainAdditionalChartDataArrays to 1 in the sc.SetDefaults code block? sc.BaseData[SC_ASK_PRICE]: This array contains the ask prices at the time of the last trade for each bar. By default, the Bid and Ask prices are only recorded when there is a trade.
When using this array in a study function, it is necessary to set sc.MaintainAdditionalChartDataArrays to 1 in the sc.SetDefaults code block. For there to be Ask prices in this array, Sierra Chart must be set to a Tick by tick Data Configuration, the Intraday data file for the chart must contain tick by tick data, and contain a Bid and Ask prices. This is not supported with all Data and Trading services. Because this should work if the above bolded part is true. if (sc.CrossOver(sc.BaseData[SC_BID_PRICE], SimpMovAvg) == CROSS_FROM_BOTTOM)
ACSIL Interface Members - Variables and Arrays: sc.BaseDataIn[][] / sc.BaseData[][] |
