Date/Time: Fri, 07 Feb 2025 13:00:18 +0000
How to delete data for specific range of dates
View Count: 1254
[2020-05-26 13:31:42] |
User781860 - Posts: 4 |
Hi, how do I delete all data for a specific instrument starting from date-time till date-time. Basically I'd like to remove yesterday's holiday data. Thanks.
Date Time Of Last Edit: 2020-05-26 13:34:48
[2020-05-30 01:32:05] |
Anyone can help with this? Thanks.
[2020-05-30 10:17:19] |
Your Sierra Chart which you have logged into this Support Board with is expired. So we know what Sierra Chart account you are using, go to Help >> Support Board from within Sierra Chart and then post in this thread telling us this is done. ---- The setting you are looking for is: Chart Settings: Set Dates To Exclude (Button) (Chart >> Chart Settings >> Chart Data >> Chart Data menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-02 13:47:51] |
User664285 - Posts: 11 |
Thanks. I'm using this one.
[2020-06-02 19:25:35] |
Ok thank you. We also did give you the relevant documentation for what you want to do in post #3.
