Date/Time: Fri, 07 Feb 2025 07:03:36 +0000
CME live data
View Count: 831
[2020-05-26 12:16:08] |
User259920 - Posts: 1 |
Hello, I have ordered Denali live data but in my Sierra I can see only delayed data for e-mini nasdaq or e-mini Es etc. Please can you help me what to do to have live data? thanks a lot David |
[2020-05-26 12:16:52] |
The reason you are not getting real-time data from the CME group of exchanges is that you activated the Non-Professional exchange fees, but you have not verified that you have a live, funded, futures trading account, which the CME needs in order to allow you data at the lower priced fees. Refer to the following for instructions on how to connect once a month to your *live funded* trading account to qualify for the lower-priced exchange fees: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees If you do not have a funded trading account or one with a supported trading service, then refer to this solution: Easy Solution to CME Funded Trading Account Requirement We recommend using the above solution in any case to avoid this problem in the future. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
