Date/Time: Fri, 07 Feb 2025 07:10:03 +0000
Create a limit order attached to the parent
View Count: 522
[2020-05-26 10:53:02] |
User261282 - Posts: 8 |
I've got an open order with a stop-loss attached. How can I add a limit order to this parent order so that it would cancel-out when the stop-loss is hit? Do I have to delete the stop-loss order and create a new OCO order, or there is a better way? |
[2020-05-26 11:46:17] |
Refer to: Attached Orders: Changing Attached Orders Configuration After Parent Order Has Filled Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
