Date/Time: Fri, 07 Feb 2025 06:44:26 +0000
Applying Automatic Trendlines Study to Another Study?
View Count: 824
[2020-05-26 02:32:40] |
User344276 - Posts: 68 |
Is it possible to apply the Automatic Trendlines study to a MACD or RSI? If it's possible, how is this done? Thanks.
[2020-05-26 04:22:45] |
Yes Automatic Trendlines can be applied to any study: Automatic Trendlines Specifically refer to: Chart Studies: Settings and Inputs Tab >> Based On - Basing a Study on Another Study We will make sure the documentation explains how to do this. But basically it involves setting the Input Data High/Low Inputs to refer to the particular Study Subgraph it is based on. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-05-26 20:40:52] |
John - SC Support - Posts: 37808 |
The documentation for how to do this is here: Automatic Trendlines: Basing Automatic Trendlines on a Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
