Date/Time: Mon, 25 Nov 2024 07:52:02 +0000
chart Values/Crosshair
View Count: 1736
[2014-01-22 18:29:37] |
tellerbe - Posts: 109 |
When I bring up my Chart Values/Crosshair,I get a drop down menu on top of my charts. How do I get rid of the drop down? T |
[2014-01-22 20:35:37] |
What are you doing to bring up the Chart Values tool?
[2014-01-22 22:08:17] |
I click on the Chart Values/crosshair button located in the tool bar at the top of the screen. TE |
[2014-01-22 23:31:04] |
And that causes a menu to appear?
[2014-01-23 19:20:41] |
I click on the tool bar,move the cursor back to the chart,click it and the cross hair comes up. With it comes a drop down that says: y 1177.4 2014-01-23 10:01:0 Net Chg -0.3 Open 11700 High 1170.6 Low 1169.6 Last 1169.6 Volume 635 I left click again. the crosshair and the drop down disappear. TE |
[2014-01-23 20:26:19] |
We think we understand. What we recommend using is Window >> Tool Values Window. When that window is open , it displays the values for the Chart Values Tool and will remain unless manually closed.
