Date/Time: Fri, 07 Feb 2025 07:09:39 +0000
SC for Denalli,OneUp and IB over API
View Count: 573
[2020-05-25 16:56:00] |
goodness - Posts: 8 |
Hi, I am using SC for the feeds above - only two to trade and one to show charts etc. At the moment (new definition CME) I cant use SC for both feeds simultanously. I am not a Pro - I have changed the ports, but the problem still remains. Can you help me - SC one of the best plattforms that actually exits. |
[2020-05-26 01:19:00] |
It looks like you are using more than one computer system. Understand the connection limits with the Denali Exchange Data Feed: Denali Exchange Data Feed: Connections Let us know if you need further help. We are not entirely sure we are understanding your question. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-26 01:19:10
