Date/Time: Fri, 07 Feb 2025 07:02:35 +0000
Problem with datafeed rhitmic and sierrachart
View Count: 637
[2020-05-25 16:23:08] |
User722634 - Posts: 6 |
Hey guys I have problems today with your sierrachart & rhitmic data feed. My connection is good and green and then i see a error message: download failed error downloading historical intraday data for xxx. historical data request rejected because the is currently another historical data request active. So then after some minutes it goes away but i saw some gaps in the charts… then i make reload again and its ok... i am now not sure is the data clean or not... can you please explain me whats happening? |
[2020-05-26 01:39:36] |
Refer to: Regarding Rithmic (Our Final Post on this Subject) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
