Date/Time: Sat, 08 Feb 2025 21:42:18 +0000
[User Discussion] - Limitorders via Spreadsheet
View Count: 652
[2020-05-25 10:25:01] |
ULADZIMIR VALASACH - Posts: 38 |
Good afternoon! I use the automatic method of trading through spreadsheets. I indicate the opening of orders through the LIMIT - but really all the same, orders are opened on the MARKET - what should I do? |
[2020-05-25 12:23:31] |
Sawtooth - Posts: 4173 |
You must also set the Limit prices in J22/J24. K3/M3 triggers the entry. J22/J24 sets the prices. J71/J73 sets the order type. Spreadsheet Systems, Alerts and Automated Trading: Limit or Stop Prices [J22, J23, J24, J25] If the Limit order is not filled, you may need a way to cancel it. Here are two examples: Spreadsheet Example Formulas and Usage: Cancel Unfilled Working Order n Minutes After Entry Spreadsheet Example Formulas and Usage: Cancel an Unfilled Order After n Bars |
[2020-05-25 13:24:55] |
You really helped - I can’t handle it myself - thank you very much!
[2020-07-29 15:58:37] |
Good day! Is it possible to work with a trigger limit in Bitmex? Installed Use Limit Chase Orders =OK, and in Spreadsheetsfortrading: Use Chase Orders = YES. Doesn't work - what to do? (Limit order is placed and it does not follow the price!) |
[2020-07-29 18:07:31] |
You also need a max value in ticks in cell J46. Spreadsheet Systems, Alerts and Automated Trading: Use Chase Orders Order Types: Limit Chase |
[2020-07-29 20:49:48] |
Thank! Posted =1 - doesn't work! |
