Date/Time: Fri, 07 Feb 2025 07:04:06 +0000
[Programming Help] - Graphical Displacement
View Count: 764
[2020-05-25 10:22:48]
User62448 - Posts: 13
Hello =)
Is there any way to set sc.Subgraph[].GraphicalDisplacement higher then 9999? My attempts to set a new limit failed.
Edit: or any other way to shift the Subgraph horizontally more then 9999 bars to right.
That would be very helpful.
Thanks!
Best regards,
Roman
Date Time Of Last Edit: 2020-05-25 10:53:03
[2020-05-25 11:12:55]
Ackin - Posts: 1865
Hi, If you want you can register on the czsk forum for download it as study.
contact link:
imagereference SG.png / V - Attached On 2020-05-25 11:12:52 UTC - Size: 28.05 KB - 225 views
[2020-05-25 12:43:03]
Thanks, let me check :)
[2020-05-25 16:01:40]
Sorry, actually I thinks its possible. I was just wondering why the input field wasnt showing the correct Displacement. It always showed 9999. Still thanks for your studie package.
[2020-05-25 17:35:24]
Ackin - Posts: 1865
I don't know what the limitations of Displacement are. The study I sent you works properly (see the attachment) so the limit for Grafical Displacement will be directly in the internal Sierrachart settings.
imageDisplacement.png / V - Attached On 2020-05-25 17:35:20 UTC - Size: 156.8 KB - 222 views
