Date/Time: Fri, 07 Feb 2025 06:49:03 +0000
Triggered Step Trailing Stop, Attached Order Parameters
View Count: 594
[2020-05-25 03:05:11] |
neodigm - Posts: 7 |
Can you please tell me what parameters Price1 and Price2 effect (e.g. Step Amount, Trigger Price, or ?) when using ModifyOrder to change an attached, triggered step trailing stop order that's been placed?
[2020-05-26 11:54:20] |
In this case only Price1 is used and it would affect the Stop order price. It is not possible to change the step amount. The Trigger Price is automatically adjusted. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
