Date/Time: Fri, 07 Feb 2025 08:01:39 +0000
Trading on Eurex and ICE
View Count: 731
[2020-05-24 16:26:38] |
T44 - Posts: 363 |
I see you discourage the use of CQG. Are there any FCMs you work with who support Eurex and ICE exchanges via your TT order routing solution? Both Dorman and AMP require to use CQG to connect to Eurex/ICE. |
[2020-05-25 13:47:44] |
AMP is expected to add ICE on TT soon.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-25 13:47:56
[2020-05-27 07:41:02] |
Marmany - Posts: 308 |
Re post #1 Does AMP require use of CQG to place orders on Eurex? I am about to fund an account with AMP in order to use Sierra order routing via TT for Eurex trades. Please advise. |
[2020-05-27 13:16:36] |
Sierra_Chart Engineering - Posts: 18326 |
No, they support EUREX on TT. And they will be adding ICE as well on TT.
