Date/Time: Fri, 07 Feb 2025 07:21:47 +0000
Attached Orders in charts - Profit Loss in Ticks
View Count: 1050
[2020-05-24 10:38:42] |
nicktrader - Posts: 734 |
Pls see pic... At the moment profit and loss are displayed in points when I move one of the Bracket Order. Where can I set that it is displayed in ticks? Many thanks |
[2020-05-24 23:00:06] |
Refer to the following Chart Setting for this: Chart Settings: Profit/Loss Format (List) (Chart >> Chart Settings >> Trading menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-05-25 04:17:31] |
Pls see pic. I am using "Ticks" but the open Bracket Order is showing Points
[2020-05-25 05:30:29] |
We looked into this, and that particular chart setting definitely affects the profit/loss display on the Attached Orders. Not sure why the Trade Position line shows a different format. Attach that chart by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-05-25 05:44:03] |
Pls see attached file I am still running 2092 because I do not like to switch at the moment Date Time Of Last Edit: 2020-05-27 04:16:42
Private File |
[2020-05-27 04:16:18] |
Any procress?
