Date/Time: Fri, 07 Feb 2025 04:52:09 +0000
custom study
View Count: 634
[2020-05-23 22:02:24] |
seangff - Posts: 16 |
Hello im looking for the custom study ecivwap1.4. Im following the SMB U futures foundation program and this is the study they have on their charts.
[2020-05-23 22:17:11] |
Ackin - Posts: 1865 |
Menu / Analysis / Studies - "Add Custom study" -> User Contributed Studies When you don't see the study in the "User contributed studies" list or it causes you problems, refer to this topic: Notice: Study Exceptions in New Versions and Code Efficiency |
[2020-05-24 16:27:34] |
Hello the user contributed studies does not show up at all. Yes i didd the newest update as suggested above
[2020-05-24 19:14:22] |
However, the UserContributeStudies.dll file is not installed with Sierra Chart by default. You need to install it by enabling the Install Optional Components option on the Sierra Chart Installer.
[2020-05-24 21:18:40] |
thank you so much for the quick responses. i plan on going live mid next week so i will do it then.
[2020-05-24 23:20:18] |
Let us know if you need more help.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-24 23:20:23
