Date/Time: Sun, 27 Sep 2026 15:58:39 +0000
No technical help Interactive Brokers
View Count: 1260
| [2020-05-23 06:23:09] |
| rvdesh - Posts: 28 |
Dear Sir, Interactive Brokers is the only broker in India with which Sierra Chart works. If you are going to dump it , please consider providing integration with Zerodha Broking Ltd, which is the largest broker in India. With over 2 + million customers and auto trading is about to explode in India, it will be an opportunity for you, continued services to clients like us. Zerodha provides broker integration through Kite Connect, which is a set of REST-like HTTP API, far superior to IBs TWS and TWS API. They already have libraries in Python, java, etc. Please check https://kite.trade/docs/connect/v3/#libraries-and-sdks. I urge you to explore this feasibility. You have successfully pursued data services of Indian exchanges from Global datafeeds. Trading integration with Zerodha will complement it significantly. Date Time Of Last Edit: 2020-05-23 06:26:30
| [2020-05-24 09:28:37] |
Yes we agree with what you say, it is just a matter of us being able to allocate the time to finish with our Indian exchange integration and increasing our development capacity which is not an easy thing.
