Date/Time: Fri, 07 Feb 2025 04:45:39 +0000
No prices on Web order entry panel
View Count: 527
[2020-05-22 19:30:46] |
curious16 - Posts: 10 |
I checked your order entry panel on the account page. I found that this panel does not display any prices. All prices are returned as zero. I have attached a screenshot to illustrate. This shows that I could login to server 2 but got no price information. Could you please check whether my account has been correctly permissioned?
Zero_prices_via _web_trading.jpg / V - Attached On 2020-05-22 19:29:58 UTC - Size: 76 KB - 215 views |
[2020-05-24 13:18:50] |
Market data support has not yet been implemented. That will be coming in a couple of months. Only trading is currently supported. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-24 13:18:58
