Date/Time: Mon, 14 Sep 2026 10:08:51 +0000
[User Discussion] - SC not using CPU fully
View Count: 732
| [2020-05-22 17:27:24] |
| Matt NL - Posts: 91 |
Hi guys Is there any way to get SC to use more than 5% of any CPU core during back testing? I'll never be able to get a good strategy built if it takes 15 minutes to QUICk test 10 days of data for each parameter I change. The accurate testing is not even worth considering at about 1 hour of testing per trading session. CPU is just sitting almost idle. It seems like SC doesn't want to use the power I have available. It would be nice to know if I could change a setting somewhere in my bios or software that will unlock the computer to do the work. I do feel it's just programmed inefficiently though and needs much improvement to make this usable for algo development. Thanks Matt |
