Date/Time: Fri, 07 Feb 2025 04:48:35 +0000
tradeguider vsa study issues after updating sierra charts to version 2109
View Count: 1257
[2020-05-22 16:08:54] |
User960421 - Posts: 1 |
Hi I have been running tradeguider vsa study (custom study addin) for several years. I have recently updated sierra charts to version 2109. The study has stopped working and produces a stream of warnings in the message log : "Warning: The Custom DLL study "TradeGuider45 Studies.scsf_TG_VSAPlugIn_4_5" has just caused a CPU exception. | 2020-05-22 16:18:42.990 * Warning: This Custom DLL study may cause AT to be unstable until you remove the study from your chart and restart AT. | 2020-05-22 16:18:42.990 * Warning: The Custom DLL study "TradeGuider45 Studies.scsf_TG_VSAScanner_4_5" has just caused a CPU exception. | 2020-05-22 16:18:42.990 * Warning: This Custom DLL study may cause AT to be unstable until you remove the study from your chart and restart AT. | 2020-05-22 16:18:42.990 * Warning: The Custom DLL study "TradeGuider45 Studies.scsf_TG_VSATrend_4_5" has just caused a CPU exception. | 2020-05-22 16:18:42.990 * Warning: This Custom DLL study may cause AT to be unstable until you remove the study from your chart and restart AT. | 2020-05-22 16:18:42.990 " I have tried various older versions,..... study will only work up to sierra version 2092 Please advise asap. Best regards Brian |
[2020-05-22 16:32:06] |
This is explained here: Notice: Study Exceptions in New Versions and Code Efficiency For now just a on an older version. You can go back with Help >> Install Previous Version. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
