Date/Time: Fri, 07 Feb 2025 07:23:00 +0000
Chartbooks
View Count: 617
[2020-05-22 15:13:45] |
User94606 - Posts: 327 |
I just upgraded to 2109 but have been using the old chartbooks prior to 2104. A couple of questions: 1. I deleted the chartbook backups by accident. Is there way to recreate them or can I save the existing chartbooks and save them as backup files? 2. Do you offer a migration tool to new chartbooks from the old one chartbook? or do I need recreate the new chartbook from scratch? 3. When creating a new chartbook in 2109, can I duplicate the charts from an old chartbooks (created prior to Sierra Chart version 2104) and send the new charts to the new chartbook created in version 2109? I am trying to find ways to simply the creation of new chartbooks. Date Time Of Last Edit: 2020-05-24 15:53:20
[2020-05-25 12:12:18] |
Sierra_Chart Engineering - Posts: 18325 |
1. Refer to the information here: Chartbooks (Workspaces): Accessing a Backup Chartbook File 2. You can open a Chartbook from prior to 2092 in any of the new versions. It will open without an issue and then you can save it again where it will be in the new format. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-05-25 12:27:12] |
Thanks. So I don't need to recreate the chartbooks from scratch
