Date/Time: Fri, 07 Feb 2025 07:16:22 +0000
Support for Live Equity Data
View Count: 525
[2020-05-22 14:37:56] |
User341752 - Posts: 26 |
Hello, With TD Ameritrade being removed as an data source, I was reading over your company supported data feed. I only need to ask 1 question: Is the real-time connection to equity markets, say NYSE or NASDAQ, $25 per month for only 20 symbols for that month or $25 per month for 20 symbols running at the same time? Thanks for the help! All the best, |
[2020-05-25 11:24:52] |
The 20 symbols in the Sierra Chart Exchange Data Feed is for receiving real-time data for 20 concurrent symbols at the same time. We also want to make sure that you are aware that the total cost is $25.00 for the 20 symbols plus $10.50 for the U.S. Equities exchange fee, so a total of $35.50 per month. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-25 11:25:26
