Date/Time: Fri, 07 Feb 2025 05:20:57 +0000
forex.com
View Count: 639
[2020-05-22 12:31:55] |
Ziklag - Posts: 73 |
Hello ...; is forex.com one of your broker/ partners, am I able to run a forex.com a/c using sierrachart?
[2020-05-22 14:06:20] |
No this is not supported. You would need to use Interactive Brokers or LMAX: Supported Data and Trading Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-22 14:06:30
