Date/Time: Fri, 07 Feb 2025 05:22:12 +0000
i need information about the platform and phillip capital.
View Count: 1465
[2020-05-22 05:14:20] |
juan gamboa - Posts: 4 |
hello I have a question, I am new here I want to know how to use the platform with phillip capital where I already have an account, but I used the ninjatrader platform I want to change and use sierra chart, I operate the Micro sp500, can I do this ..? Thank you in advance for your help.
[2020-05-22 15:19:05] |
Yes you can do this but you need to have an account directly with Philip Capital and use the Sierra Chart Order Routing service: Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-22 15:19:24
[2020-05-22 15:40:57] |
SC Support - Posts: 1927 |
Hi juan gamboa, your first call should be to Phillip Capital, (do you need a contact there?), as you are correct the NinjaTrader Brokerage does not support the TT Order Routing Collaboration. Sierra Chart / Trading Technologies Futures Order Routing Service |
[2020-05-22 19:25:30] |
ok I understand, I honestly have no contact in phillip capital, I must search. The entire procedure is done through the ninjatrader in due course. i´m enormously grateful for the time taken in my. |
[2020-05-22 19:27:16] |
if you have a contact there in phillip capital I would greatly appreciate it, thanks.
[2020-05-22 19:49:34] |
We asked Phillip Capital for a contact person and they advised us that the client can contact NinjaTrader Brokerage, however we do see that Phillip Capital take clients directly (https://openaccount.phillipusa.com/ApplicantType +1 312 356 9000) so you can start there.
[2020-05-22 20:36:56] |
thanks i'm really very grateful.
