Date/Time: Fri, 07 Feb 2025 05:21:29 +0000
Nikkei 225 intrday Chart not loading
View Count: 724
[2020-05-22 04:31:41] |
User362809 - Posts: 1 |
I just checked and apparently all my data is delayed
[2020-05-22 05:20:17] |
Please contact your broker about this. You are using CQG.
