Date/Time: Fri, 07 Feb 2025 06:53:56 +0000
TPO Chart Displaying Differently Than Friend's
View Count: 675
[2020-05-22 02:22:59]
User518675 - Posts: 2
I have a friend who sent me a TPO chart, however when loaded on my computer it displays drastically different than what is seen on his. Note what I have circled in red, the open and closes are very different, as well as the range, etc. Opening a candle chart for the same period, I can clearly see that mine is the one displaying the incorrect values. How do I fix this?
Thanks!
imageTPO Differences.jpg / V - Attached On 2020-05-22 02:20:08 UTC - Size: 348.96 KB - 216 views
[2020-05-22 15:42:16]
This will be the relevant section for this:
Working With Charts: Resolving Differences of Chart Bars Between Charts
[2020-05-23 02:31:43]
Thanks, I went through all that and still have the problem.
With further investigation I found out that Sierra is using Saturday close values to close/open the week where as it should be using Sunday. I went through all the daily candles and compared them and Saturday's closes line up perfectly with where Sierra is closing the week. I saw a help page on reverse session times, but that isn't my problem either because I have my start time set to 00:00:00 and end time set to 23:59:59. Do you have any ideas what could be causing this?
[2020-05-25 11:44:55]
Check this setting:
General Settings Window: Use Monday as Start of Week instead of Sunday (Global Settings >> General Settings >> General >> Data)
