Date/Time: Fri, 07 Feb 2025 04:42:41 +0000
Switching from IB to TT
View Count: 506
[2020-05-22 01:48:38] |
madness99 - Posts: 35 |
Hi, Here is my question on using TT. I work for a bank and they require me to use certain bokerage houses. AMP is out of question, since is not an approve broker. The only platform Sierra Chart works with is IB. If I use TT, where will I fund my brokerage house? Thanks J |
[2020-05-22 13:29:34] |
If you need to use Interactive Brokers for that reason, then continue to use them irrespective of our complaints about them. But in the case of using the Sierra Chart Order Routing service based on TT, there are many clearing firms you can use which include Advantage and Phillips Capital. They are all listed here: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-22 13:30:38
