Date/Time: Fri, 07 Feb 2025 05:00:09 +0000
Blank Charts
View Count: 898
[2020-05-22 00:14:04] |
User716575 - Posts: 24 |
Hi I'm having issues with my charts. All charts are blank. I added some custom chart books and now I'm getting this message. Caught an unhandled exception in c_ chart: window proc. message 15, wParam 0, IParam: 2020-05-21 John |
[2020-05-22 15:16:16] |
First thing we want you to do is to run Sierra Chart in Safe Mode: Sierra Chart - Software Login Instructions: Using Safe Mode And update Sierra Chart to the current version: Software Download: Fast Update And translate symbols to the current service: Edit Menu: Edit >> Translate Symbols To Current Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
