Date/Time: Tue, 06 Oct 2026 11:12:59 +0000
bracket configuration
View Count: 1946
[2020-05-21 22:03:44]
User572213 - Posts: 3
I trade the Es and I cant figure out how to configure a bracket order.I would like to trade 3 contracts.I would like to place a safety stop on all 3 contracts at 12 ticks offset from entry price.Then I would like to take a profit of 4 ticks on 2 contracts.If this criteria is met I would like to trail the stop on the 1 remaining contract 4 ticks offset from the entry price. Also on the remaining contract I would like to have a profit order at the time of entry set for 20 ticks. Can you please explain to me how to do this.
James W B
[2020-05-29 12:44:59]
We apologize for the delay. Do you still want help with this? We will need to provide an example Trade Window Configuration file.
[2020-05-29 18:42:16]
Yes I would still like help
[2020-05-29 20:28:07]
Sierra_Chart Engineering - Posts: 25070
The Trade Window Configuration file is attached. Refer to:
Basic Trading and the Trade Window: Using a Trade Window Configuration File Provided to You
attachmentUser572213_Strategy.twconfig - Attached On 2020-05-29 20:27:01 UTC - Size: 4.86 KB - 712 views
[2020-05-30 16:35:07]
The user file wont open . Could you please re send
[2020-05-31 09:14:08]
We confirmed that this file does load properly:
https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=39706
We have also reactivated your Sierra Chart trial but that is not relevant.
We want you to update Sierra Chart to the current version:
The issue might be relevant to that.
And here are the instructions to use the file again:
Date Time Of Last Edit: 2020-05-31 09:14:19
