Date/Time: Fri, 07 Feb 2025 06:47:31 +0000
View full market depth - more than 10 levels on DOM Graph
View Count: 2856
[2020-05-21 20:54:24] |
User882670 - Posts: 15 |
I have CQG subscription with Market depth but I am able to see only 10 levels on DOM graph If I understand it correctly I can see whole market depth (more than 10 levels) with SierraChart datafeed. But it is not clear to me how to enable it. Do I need to go through this page and activate it? https://www.sierrachart.com/UserControlPanel.php?page=ExchangeDataFeedFeatures And in order to trade ES on top of that I should ave some basic CQG datafeed for CME (top of book) ? So I would be able to see full market depth and full DOM like in attached screenshot? |
Private File Attachment Deleted. Private File |
[2020-05-22 13:55:20] |
No that is not the right page. You need to use the Denali Exchange Data Feed: Denali Exchange Data Feed And in order to trade ES on top of that I should ave some basic CQG datafeed for CME (top of book) ?
You will not need to use the CQG data feed any longer. If you are trading just the CME group of markets we recommend changing to this service:Sierra Chart / Trading Technologies Futures Order Routing Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-22 13:56:24
[2020-05-22 19:17:24] |
Let me be sure if I understand correctly: I am with AMP so I should chose TT/Denali as on attached screenshot and then proceed with the steps to assign Sierra Chart for routing? |
[2020-05-25 11:43:11] |
Yes, except that you only need to select the $10.00 CME option on the AMP page, not both of the CME items. Once AMP has you setup, you would then start at step #9 of the Setup Instructions here: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
