Date/Time: Fri, 07 Feb 2025 06:58:03 +0000
[Programming Help] - Montreal exchange futures
View Count: 965
[2020-05-21 20:48:06] |
User236880 - Posts: 15 |
Can you show me how to import the 5yr canadian bond futures (CGF) and the BAX money market futures. Both are on the montreal exchange. Similar to the CGB that is setup (10yr)
[2020-05-22 14:43:13] |
This is available. Use the Sierra Chart Historical Data Service: Sierra Chart Historical Data Service Symbols are in File >> Find Symbol>>-Futures-MNTRL Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-22 14:43:23
[2020-05-22 19:04:22] |
It doesnt seem to be available when im connected through Interactive Brokers
[2020-05-25 11:41:49] |
We cannot help with Interactive Brokers as we have terminated technical support for that service. You need to use the Sierra Chart Historical Data service and the documentation we linked to above explains to install a separate copy of Sierra Chart for that. That is what you need to do. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
