Date/Time: Fri, 07 Feb 2025 05:06:36 +0000
Crosshair
View Count: 777
[2020-05-21 19:35:56]
User51148 - Posts: 8
Can you tell me why the chartvalue/crosshair [Alt-3] shows only a vertical line and NOT THE HORIZONTAL LINE?
[2020-05-21 21:42:41]
ondafringe - Posts: 298
Go to Tools > Tool Settings... then click the Chart Values tab... check the appropriate box(es).
[2020-05-22 15:14:05]
This is configurable. Refer to:
Chart Drawing Tools: Chart Values Tool Configuration
[2020-05-22 15:14:06]
