Date/Time: Tue, 04 Nov 2025 18:18:03 +0000
GetTradingDayStartDateTimeOfBar in 965 issue?
View Count: 2671
| [2013-04-16 01:21:07] |
| onnb - Posts: 664 |
Hi everyone, A study that works correctly in 963 stopped working in 965. It looks to be related to GetTradingDayStartDateTimeOfBar. In 965, the method consistently returns -9.2559592131366316e+061 Any ideas? Onn |
| [2013-04-16 01:36:11] |
Did you recompile on 965? Make sure you are using the latest header file.
| [2013-04-16 01:57:17] |
| onnb - Posts: 664 |
Recompile looks to solve the issue. 1. I am assuming that all DLL's that use this method need to be upgraded with 965? 2. Are there other methods would require a recompile? Onn |
| [2013-04-16 02:53:07] |
It would appear so but we are not sure why. If you are using other functions which take a Date-Time value or return one, then you may need to recompile those studies as well. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-04-16 03:09:30
| [2013-04-16 02:57:45] |
| onnb - Posts: 664 |
If that's the case, and I am not sure you can do this, but I suggest you have a note and even a warning in the application that existing dll needs to be recompiled. DateTime based methods are quite common. |
| [2013-04-16 03:13:01] |
This would be very hard to implement in this particular case and this problem is completely unexpected. A recompile should not be necessary. We will mention that a recompile is apparently necessary on the What's New page. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
