Date/Time: Mon, 12 Oct 2026 20:49:14 +0000
SC not responding during backtesting
View Count: 992
[2020-05-21 03:52:36]
trading2themoon - Posts: 46
Everything working fine, then suddenly this evening it starts chugging and not responding whenever I try to replay or run an automated backtest. I've closed the chart book and opened a new chart, set the days count to 1 and the spreadsheet rows to 150 (used to have it on 10 days and 1000 rows). I haven't added any new studies or custom studies. What could be the problem?
[2020-05-21 13:01:20]
I now see that my .scss file is over 50MBs. All my other .scss files were under 2MBs. I checked and there are still only 200 rows of data being stored. Any suggestions as to how I can reduce the file size or what might have gone wrong?
[2020-05-21 19:12:44]
ForgivingComputers.com - Posts: 1239
Check for sheets that are not being used and delete them.
[2020-05-21 19:15:47]
I had four sheets used as backups (since there's no versioning tool). But very little data in them.
[2020-05-23 10:46:33]
The first thing is to check the replay mode:
https://www.sierrachart.com/index.php?page=doc/ReplayChart.html#ReplayMode
Try using this replay mode: Calculate Same as Real Time
You just need to delete the data from the unused rows and columns:
Using the Spreadsheet Study: Clearing Old Study and Other Data from Spreadsheets
Also use a lower Replay Speed.
