Date/Time: Fri, 07 Feb 2025 04:01:14 +0000
Can't adjust drawn volume profile
View Count: 779
[2020-05-20 20:02:15] |
MFT_ - Posts: 12 |
Hey guys, I'm having difficulties with adjusting drawn volume profiles which i can't adjust. I have to remove the drawing in my studies and draw it again. I have this problem on my desktop but not on the laptop. Both devices are running on the current SC version. Hope you guys can help me out. |
[2020-05-21 12:02:22] |
Check your Tool Settings and make sure they are the same between the systems. In particular the following items: Chart Drawing Tools: Enable Drawn Volume Profile Selection (Global Settings >> Tool Settings >> General >> Volume Profiles) and Chart Drawing Tools: Select Drawn Volume Profile by Outline Only (Global Settings >> Tool Settings >> General >> Volume Profiles) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
