Date/Time: Fri, 07 Feb 2025 07:12:10 +0000
Customized menu items & new sub-instance
View Count: 634
[2020-05-20 18:06:48]
jwick - Posts: 142
When creating a new sub-instance, customized menu items aren't replicated within the sub-instance. As an example: I changed the menu item name for Split Profiles to zSplitProfiles. Restarted SC. Then went File -> New Instance. In the new sub-instance, Split Profiles isn't zSplitProfiles but instead uses the default text for that menu item.
[2020-05-21 08:51:38]
We will solve this in the next release.
[2020-05-25 14:20:28]
jwick - Posts: 142
It appears that symbol settings (eg: per-symbol R/T commission values) are also not carried over when creating a new instance.
[2020-05-26 01:49:20]
There is a setting to control this in the Global Symbol Settings:
Global Symbol Settings: Use These Symbol Settings in New Instances When Started (Global Settings >> Symbol Settings)
