Date/Time: Fri, 07 Feb 2025 09:44:30 +0000
Tradovate
View Count: 1718
[2020-05-20 16:23:54] |
User166951 - Posts: 24 |
I trade futures via Tradovate. Can I use their data and can I trade off Sierra Charts and push the trades to Tradovate?
[2020-05-20 19:34:46] |
Yes by using CQG: CQG Trading Platform Service But that is not the preferred solution. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-05-20 19:55:43] |
Is the preferred method Dinali data? Also, can I route orders to my Tradovate account? Thanks. |
[2020-05-21 11:30:56] |
Yes you could use the Denali data feed. Although using CQG is fine as well. And yes the orders will route in either case to your Tradovate account. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-05-29 22:15:04] |
Richard Villarreal - Posts: 4 |
I just set up my account to trade futures with Tradovate and would like to use Sierra (Package 5) with the Denali feed. Were you able to get your account configured with Tradovate and Sierra? If so, so can you please provide some guidance. I'm a bit confused as to how to go about setting this up. Much appreciated!
[2020-05-30 10:07:00] |
In the case of Tradovate you need to use CQG: CQG Trading Platform Service: Setup Instructions And then follow the instructions here for the Denali Exchange Data Feed: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
