Date/Time: Fri, 07 Feb 2025 20:29:34 +0000
Elder Impulse
View Count: 1695
[2020-05-20 15:25:58]
User166951 - Posts: 24
Does Sierra Chart have the Elder Impulse indicator that colors the bars based on momentum? My current chart (Tradovate) combines a 13 EMA with the MACD to find market momentum. When the two indicators align, they show an impulse move.
Thanks,
Bruce
[2020-05-20 16:07:06]
Ackin - Posts: 1865
I have several versions ... can you send a picture of what you are currently using?
[2020-05-20 16:14:26]
I have attached the calculation as well as a screen shot showing the colored bars.
imageElder Calculation.png / V - Attached On 2020-05-20 16:13:34 UTC - Size: 73.41 KB - 368 views
imageElder Bars.png / V - Attached On 2020-05-20 16:13:45 UTC - Size: 34.14 KB - 373 views
[2020-05-20 18:07:43]
Ackin - Posts: 1865
Yes...I should have it. I'll go through the old studies I created ... or I'll do it again, that's a maximum of 20 lines of code.
Date Time Of Last Edit: 2020-05-20 18:09:03
[2020-05-21 13:31:50]
Good morning...
Do you have any ETA for the Elder Impulse indicator availability?
Bruce
[2020-05-22 16:37:50]
Ackin - Posts: 1865
Yes I have ... On Sunday I will be giving a new update with the ZigZag universal divergence study and the correction of some other studies, so I can add this (what you want) to it. You can register and download on Sunday ...
contact link:
[2020-05-22 19:47:36]
SC Support Tom - Posts: 450
Hi, I have looked over the attachments in Post #3. We can have this indicator ready by Monday.
[2020-05-22 20:31:05]
Ackin - Posts: 1865
perfect ... we will compare at least the results :)
[2020-05-24 22:49:31]
Ackin - Posts: 1865
Good morning...
Bruce
imageElder Impulse system.png / V - Attached On 2020-05-24 22:47:57 UTC - Size: 33.19 KB - 356 views
[2020-05-27 10:07:02]
Hello, I am working on this study. I still have a bug to iron out, but I should be done soon. Thanks for your patience.
[2020-06-12 18:33:32]
This study has been added. The documentation is here.
Elder Impulse
